13 years ago.
STRING TO DECIMAL
is there any command that i can convert a ASCII data to a decimal number.
13 years ago.
sscanf is probably fits your requirements best, see: http://www.cplusplus.com/reference/cstdio/sscanf/, see also scanf there for a bit more examples.
So you would get something for an integer like:
char numberstring[] = "42";
int number;
sscanf(numberstring, "%d", &number);
I have a program like this.
rx[1]='5'; float r;
sscanf(rx[1],"%f",&r);
BUT IT DOES'T WORK BECAUSE THERE IS A PROBLEM THAT TELLS :"char is incompatible with the parameter const"
i need that mi variable r get the rx[1]:
r=5;???
posted by Danilo Teran 05 Apr 2013
Do you only have a single char? So no string? Then you can use:
float r = rx[1] - 48;
Since in ascii numbers start at 48.
But you can also use sscanf, how did you define rx? You need to put just 'rx' in the sscanf function, not rx[1].
posted by Erik - 06 Apr 2013
