8 years, 9 months ago.
Dragonfly GPS not working while TCP connection is enabled?
I am using MTS Dragonfly to sned GPS data using MQTT. But GPS cannot be enabled when TCP socket is open. I need to disconnect from the TCP connection to get GPS data. Whenever I try to enable GPS when TCP connection is already established, I get the error:
Quote:
socket is open. Can not send AT commands
Is it possible in Dragonfly to run TCP and GPS simultaneously?
Assigned to 8 years, 9 months ago.
Is this already fixed/solved?
posted by Adriaan Kooderings Clemens 08 Oct 2017
