8 years, 10 months ago.
MAX32630FTHR -Compilation Error help
I need some one help me understand and solve the compilation error in my code for MAX32630FTHR as target.
I get errors like below 1)Error: Identifier "M1B" is undefined in "test.cpp", Line: 63, Col: 2 for variable like M1A,M2A and M2B.
I have define this variables at the start of the code as below,cant understand why this error occurs. DigitalOut M1A(P5_0); DigitalOut M1B(P5_1); DigitalOut M2A(P5_6); DigitalOut M2B(P5_5);
2) Error: Function "speedmap" has already been defined in "test.cpp", Line: 69, Col: 8) But i have defined this at only one place
I do have some more errors(attached a image) ,it would of great help if someone can help me out of this problem, since i am a newbie to programming and from H/W background.
Attached the code fyr(some portions of the actual code are commented due to development phase) /media/uploads/sharish7/code.txt
Regards, Harish.S
Looks like you are missing a semicolon at the end of the first occurence of speedmap (around line 17). That confuses the compiler and leads to skipping the M1A etc declarations, leading to more errors.
