8 years, 10 months ago.
Example code using VL53L0X Satellites (WITHOUT USING X-NUCLEO-53L0A1)
I have been struggling for many many hours trying to get the VL53L0X Satellites ToF range sensor to work with my Nucleo-F446RE with no success whatsoever. Does anyone have a simple example code I can use to get started with, that does not rely on the expansion board?
Any help would be greatly appreciated. Thank you!
Shiloh
Shiloh,
Are you trying to just get the VL53L0X sensor to work itself via i2c?
Have a look at my repo at: https://github.com/ARMmbed/VL53L0X-mbedOS
This is a simple program with the libraries, it should get it up and running.
Andrea, team mbed
Hi Andrea,
I am wanting to use the sensors with I2C. Thank you for sharing your code. I have tried to run your code but for some reason, i am only getting an output value of 0. I have run the expansion board example and that works so the pin assignments can be the only issue, I am using: D15, D14 (SCL, SDA). Where in the code do I change this?
Shiloh
posted by 02 Jun 2017Hi again,
I have now changed the i2c( ) to the correct pin outs. But for some unknown reason, I am still getting an output of 0mm. Does anyone have any ideas here?
Thanks
Shiloh
posted by 26 Jun 2017Hi , I am trying this code too, but i got 0 mm as the above, but if i change the I2C i2c(PF_0, PF_1) in Vl53L0x_i2c_platform.cpp to I2C i2c(I2C_SDA, I2C_SCL); the value is always 3208 . I can't figure out where is the mistake . Does your code run on your board successfully?
Thanks
Johnny
posted by 29 Jan 2018
