8 years, 9 months ago.
It looks like PA_12 can't be an Interrupt IN
Every thing is in the title... It's written that all pins can be InterruptIn but test on PA_12 are showing the exact opposite !
How to be ripped off
Serial      Pc      (PA_2, PA_3, 460800);
DigitalOut  Trig1   (PC_3);
DigitalOut  Trig2   (PC_2);
DigitalOut  Trig3   (PA_9);
DigitalOut  Led1    (PA_5);
DigitalOut  Led2    (PD_2);
InterruptIn Echo1   (PA_12);
InterruptIn Echo2   (PA_11);
InterruptIn Echo3   (PB_12);
Ticker      timer;
Timer       temps;
int         FlagUS1 = 0, FlagUS2 = 0, FlagUS3 = 0;
long        Echo1Start, Echo2Start, Echo3Start;
double      DistUS1, DistUS2, DistUS3;
void echo1Rise ()
    Echo1Start = temps.read_us();
void echo2Rise ()
    Echo2Start = temps.read_us();
    Led2 = !Led2;
void echo3Rise ()
    Echo3Start = temps.read_us();
void echo1Fall ()
    DistUS1 = (double)(temps.read_us() - Echo1Start)/5.8;
    FlagUS1 = 1;
void echo2Fall ()
    DistUS2 = (double)(temps.read_us() - Echo2Start)/5.8;
    FlagUS2 = 1;
void echo3Fall ()
    DistUS3 = (double)(temps.read_us() - Echo3Start)/5.8;
    FlagUS3 = 1;
void tickTime()
    Tick++;
    FlagTick = 1;
    if ((Tick%100)==0)  FlagTickLed = 1;
    temps.reset();
    temps.start();
    timer.attach(&tickTime, 0.001);
    Echo1.rise (&echo1Rise);
    Echo2.rise (&echo2Rise);
    Echo3.rise (&echo3Rise);
    Echo1.fall (&echo1Fall);
    Echo2.fall (&echo2Fall);
    Echo3.fall (&echo3Fall);
    Echo1.enable_irq();
    Echo2.enable_irq();
    Echo3.enable_irq();
    Led2 = 0;
    Led1 = 0;
    while (1) {
            do {
                    if (FlagTickLed) {
                        Led1 = !Led1;
                        FlagTickLed = 0;
                    // Gestion des US
                    if (((Tick%150)==0) && FlagTick) {
                        Trig1 = 1;
                        wait_us(15);
                        Trig1 = 0;
                        FlagTick = 0;
                    if (((Tick%150)==50) && FlagTick) {
                        Trig2 = 1;
                        wait_us(15);
                        Trig2 = 0;
                        FlagTick = 0;
                    if (((Tick%150)==100) && FlagTick) {
                        Trig3 = 1;
                        wait_us(15);
                        Trig3 = 0;
                        FlagTick = 0;
                    if (FlagUS1==1) {
                        Pc.printf ("\rUS 1 = %04d mm", (int)DistUS1);
                        FlagUS1 = 0;
                    if (FlagUS2==1) {
                        Pc.printf ("\r\t\t\tUS 2 = %04d mm", (int)DistUS2);
                        FlagUS2 = 0;
                    if (FlagUS3==1) {
                        Pc.printf ("\r\t\t\t\t\t\tUS 3 = %04d mm", (int)DistUS3);
                        FlagUS3 = 0;
                } while(!Pc.readable());
Does Anyone experience the same problem ?
Affordable and flexible platform to ease prototyping using a STM32F446RET6 microcontroller.
If you look at the datasheet you'll see that PA_12 *can* in fact be an interrupt in. However it also states that only *one* source per numeric-input can be provided to the interrupt-input multiplexer. The problem you are having is that you created an instance of InterruptIn Echo3(PB_12). This will cause the initializer to switch the 12th source interrupt input over to PB_12. Try commenting out Echo3 and see if Echo1 starts working. Then you will need to find an appropriate available input on a different numeric input for Echo3.
In other words: PA_12 or PB_12 or PC_12 or PD_12 (etc..) can be the 12th external interrupt source. But only *one* of those inputs! Choose another numeric input for the next interrupt etc..
Thanks for your answer I'm going to make 2 new straps on my PCB, I guess I haven't read it from any (short) document, How have you find this (reading the 1750 pages user manual ???). By the way thanks a lot...
posted by H A 27 May 2017
One more thing : I Beleive that it's the same for Analog In, am I wrong ?
It's not up front in the datasheet and when I had a similar problem I found it in the reference manual. Hope you get it working!
posted by Bill Bellis 28 May 2017
