8 years, 10 months ago.
Heap Stack Issue in IAR
hi,
i'm facing issue with HEAP memmory in IAR toolchain. my board have 16KB RAM.
in Greentea test "rtos-rtx-target_cortex_m-tests-memory-heap_and_stack" testcase is failing when im configuring STACK=0x400 and HEAP =0x000 in xxxxx.icf file.
All other testcases are passing in greentea.
if i change HEAP to 0x800 , that test case is PASS,but "features-tests-filesystem-heap_block_device" , "tests-mbedmicro-rtos-mbed-semaphore" and " tests-mbedmicro-rtos-mbed-threads" are failing due HEAP limit.
How to resolve this issue?
All test cases are Passing with ARM and GCC_ARM tool-chain.
