8 years, 10 months ago.
Bluetooth Connectivity to Windows PC for data logging
The maxim health sensor platform connects to the PC via USB and an Android App with bluetooth, I would like to be able to connect to the PC (windows 10) via bluetooth as well for data logging remotely. Is this possible? At present i am unable to pair it to my PC. It board shows on the PC as 'ready to pair', but does not pair.
Thank you and your help would be greatly appreciated
Hello Nikhil,
In theory it is possible, however a Windows application that supports data logging over bluetooth would have to be developed and this wasn't part of the specification for this project.
Justin
Hello Nikhil,
Some more info, the HSP platform is BLE. Most PC's only support BT Classic.
Justin
posted by 24 May 2017Hi Justin,
Thank you for your prompt response, your answer was helpful. I appreciate it. Just to sum up - Firstly, BLE connectivity between the HSP board and windows PC is not available since the GUI application was designed to connect wirelessly only to Android devices using BLE. Secondly, BLE capability also depends on the PC OS. Would that be accurate? Thanks in advance.
- Nikhil
posted by 25 May 2017
