8 years, 9 months ago.
[C027] CellLocate results are different , using the tool(m-center) and using the mbed code.Why?
When CellLocate is done with mbed-C027, the results are different when using the tool and when using the mbed code.Why?
  • tool result:35.7037449,139.7623999
  • mbed result: latitude: 36.00000, longitude: 138.00000
Are they rounded off?
I think the cause is a parser of MDM.cpp. Is not there a mistake when getting floating point with sscanf? It is the following part.
}else if (sscanf(cmd, "UULOC: %d/%d/%d,%d:%d:%d.%*d,%f,%f,%d,%d,%d,%d,%d,%d,%d,%*d,%*d",\
                        &_loc[0].time.tm_mday, &_loc[0].time.tm_mon, &_loc[0].time.tm_year, &_loc[0].time.tm_hour, &_loc[0].time.tm_min, &_loc[0].time.tm_sec,\
                        &_loc[0].latitude, &_loc[0].longitude, &_loc[0].altitutude, &_loc[0].uncertainty, &_loc[0].speed, &_loc[0].direction, &_loc[0].verticalAcc, \
                        &b, &_loc[0].svUsed) == 15) {
                    TRACE("Parsed UULOC position at index 0\r\n");
Original source is https://developer.mbed.org/teams/ublox/code/C027_Support/
[1] is mbed run log [2] is m-center log [3] is source code
[1]
Modem::wakeup
Modem::init
Modem::devStatus
  Device:       LISA-U2
  Power Save:   Disabled
  CCID:         8981100023561854336
  IMEI:         352648069548865
  IMSI:         440103148290527
  Manufacturer: u-blox
  Model:        LISA-U200
  Version:      22.90,A01.01
Modem::register
Modem::netStatus
  CSD Registration:   Home
  PSD Registration:   Home
  Access Technology:  3G
  Signal Strength:    -69 dBm
  Bit Error Rate:     25
  Operator:           NTT DOCOMO
  Location Area Code: 00EC
  Cell ID:            0448402F
Modem::join
Modem:IP 100.96.76.190
Make a Http Post Request
Socket Recv "HTTP/1.1 200 OK
Server: nginx/1.11.12
Date: Thu, 11 May 2017 01:58:12 GMT
Content-Type: text/plain
Content-Length: 14
Connection: close
Last-Modified: Fri, 27 Jul 2012 13:30:34 GMT
Accept-Ranges: bytes
Cache-Control: max-age=36000
Expires: Thu, 1"
Testing TCP sockets with ECHO server
Socket Send 31 "
TCP Socket Hello World
End
Socket Recv 63 "u-blox AG TCP/UDP test service
End
Testing UDP sockets with ECHO server
Socket SendTo echo.u-blox.com:7 195.34.89.241 31 "
UDP Socket Hello World
End
Socket RecvFrom 195.34.89.241:7 31 "
End
Modem::disconnect
Ussd Send Command *130#
SMS and GPS Loop
Command not supported
CellLocate Request
Waiting for CellLocate...
CellLocate Request
CellLocate position received, sensor_used: 0,
  latitude: 0.00000, longitude: 0.00000, altitute: 0
CellLocate Request
  latitude: 36.00000, longitude: 138.00000, altitute: 0 <------------------------------------------------------------------------*1
CellLocate Request
CellLocate Request
CellLocate Request
[2]
AT+UGAOP="eval1-les.services.u-blox.com",46434,1000,0
OK
AT+ULOCCELL=0
OK
AT+ULOC=2,2,1,100,5000
OK
+UULOC: 01/01/2004,00:03:19.000,0.0000000,0.0000000,0,20000000,0,0,0,0,0,0,0
OK
AT+ULOCCELL=0
OK
OK
+UULOC: 11/05/2017,02:09:53.000,35.7037449,139.7623999,50,1000,0,0,0,2,0,0,0 <-------------------------------*2
[3]
int main(void)
    int ret;
#ifdef LARGE_DATA
    char buf[2048] = "";
#else
    char buf[512] = "";
#endif
    // Create the GPS object
#if 1   // use GPSI2C class
    GPSI2C gps;
#else   // or GPSSerial class
    GPSSerial gps;
#endif
    // Create the modem object
    MDMSerial mdm; // use mdm(D1,D0) if you connect the cellular shield to a C027
    //mdm.setDebug(4); // enable this for debugging issues
    // initialize the modem
    MDMParser::DevStatus devStatus = {};
    MDMParser::NetStatus netStatus = {};
    bool mdmOk = mdm.init(SIMPIN, &devStatus);
    mdm.dumpDevStatus(&devStatus);
    int ret;
    char buf[256] = "";
    //give time to module for powering up (ms)
    wait_ms(1000);
    MDMSerial mdm;
    mdm.set_flow_control(SerialBase::RTSCTS, MDMRTS, MDMCTS);
    wait(5);
    if (mdmOk) {
        // wait until we are connected
        mdmOk = mdm.registerNet(&netStatus);
        mdm.dumpNetStatus(&netStatus);
    if (mdmOk)
        // join the internet connection
        MDMParser::IP ip = mdm.join(APN,USERNAME,PASSWORD);
        if (ip == NOIP)
            printf("Not able to join network");
        else
            mdm.dumpIp(ip);
            printf("Make a Http Post Request\r\n");
            int socket = mdm.socketSocket(MDMParser::IPPROTO_TCP);
            if (socket >= 0)
                mdm.socketSetBlocking(socket, 10000);
                if (mdm.socketConnect(socket, "mbed.org", 80))
                    const char http[] = "GET /media/uploads/mbed_official/hello.txt HTTP/1.0\r\n\r\n";
                    mdm.socketSend(socket, http, sizeof(http)-1);
                    ret = mdm.socketRecv(socket, buf, sizeof(buf)-1);
                    if (ret > 0)
                        printf("Socket Recv \"%*s\"\r\n", ret, buf);
                    mdm.socketClose(socket);
                mdm.socketFree(socket);
            int port = 7;
            const char* host = "echo.u-blox.com";
            MDMParser::IP ip = mdm.gethostbyname(host);
            char data[] = "\r\nxxx Socket Hello World\r\n"
                        "End\r\n";
            printf("Testing TCP sockets with ECHO server\r\n");
            if (socket >= 0)
                if (mdm.socketConnect(socket, host, port)) {
                    memcpy(data, "\r\nTCP", 5);
                    ret = mdm.socketSend(socket, data, sizeof(data)-1);
                    if (ret == sizeof(data)-1) {
                        printf("Socket Send %d \"%s\"\r\n", ret, data);
                    if (ret >= 0) {
                        printf("Socket Recv %d \"%.*s\"\r\n", ret, ret, buf);
            printf("Testing UDP sockets with ECHO server\r\n");
            socket = mdm.socketSocket(MDMParser::IPPROTO_UDP, port);
            if (socket >= 0)
                memcpy(data, "\r\nUDP", 5);
                ret = mdm.socketSendTo(socket, ip, port, data, sizeof(data)-1);
                    printf("Socket SendTo %s:%d " IPSTR " %d \"%s\"\r\n", host, port, IPNUM(ip), ret, data);
                ret = mdm.socketRecvFrom(socket, &ip, &port, buf, sizeof(buf)-1);
                if (ret >= 0) {
                    printf("Socket RecvFrom " IPSTR ":%d %d \"%.*s\" \r\n", IPNUM(ip),port, ret, ret,buf);
            // disconnect
            mdm.disconnect();
        // http://www.geckobeach.com/cellular/secrets/gsmcodes.php
        // http://de.wikipedia.org/wiki/USSD-Codes
        const char* ussd = "*130#"; // You may get answer "UNKNOWN APPLICATION"
        printf("Ussd Send Command %s\r\n", ussd);
        ret = mdm.ussdCommand(ussd, buf);
        if (ret > 0)
            printf("Ussd Got Answer: \"%s\"\r\n", buf);
    printf("SMS and GPS Loop\r\n");
    char link[128] = "";
    unsigned int i = 0xFFFFFFFF;
    const int wait = 100;
    bool abort = false;
#ifdef CELLOCATE
    const int sensorMask = 3;       // Hybrid: GNSS + CellLocate
    const int timeoutMargin = 5;    // seconds
    const int submitPeriod = 60;    // 1 minutes in seconds
    const int targetAccuracy = 1;   // meters
    unsigned int j = submitPeriod * 1000/wait;
    bool cellLocWait = false;
    MDMParser::CellLocData loc;
    //Token can be released from u-blox site, when you got one replace "TOKEN" below
    //// if (!mdm.cellLocSrvHttp("TOKEN"))
    if (!mdm.cellLocSrvTcp("TOKEN"))
            mdm.cellLocSrvUdp();
    /// mdm.cellLocConfigSensor(1);
    mdm.cellLocConfig(1);           // Deep scan mode            +ULOCCELL
    //mdm.cellUnsolIndication(1);
#endif
    DigitalOut led(LED1);
    while (!abort) {
        led = !led;
#ifndef CELLOCATE
        while ((ret = gps.getMessage(buf, sizeof(buf))) > 0)
            int len = LENGTH(ret);
            //printf("NMEA: %.*s\r\n", len-2, msg);
            if ((PROTOCOL(ret) == GPSParser::NMEA) && (len > 6))
                // talker is $GA=Galileo $GB=Beidou $GL=Glonass $GN=Combined $GP=GPS
                if ((buf[0] == '$') || buf[1] == 'G') {
                    #define _CHECK_TALKER(s) ((buf[3] == s[0]) && (buf[4] == s[1]) && (buf[5] == s[2]))
                    if (_CHECK_TALKER("GLL")) {
                        double la = 0, lo = 0;
                        char ch;
                        if (gps.getNmeaAngle(1,buf,len,la) &&
                            gps.getNmeaAngle(3,buf,len,lo) &&
                            gps.getNmeaItem(6,buf,len,ch) && ch == 'A')
                            printf("GPS Location: %.5f %.5f\r\n", la, lo);
                            sprintf(link, "I am here!\n"
                                          "https://maps.google.com/?q=%.5f,%.5f", la, lo);
                    } else if (_CHECK_TALKER("GGA") || _CHECK_TALKER("GNS") ) {
                        double a = 0;
                        if (gps.getNmeaItem(9,buf,len,a)) // altitude msl [m]
                            printf("GPS Altitude: %.1f\r\n", a);
                    } else if (_CHECK_TALKER("VTG")) {
                        double s = 0;
                        if (gps.getNmeaItem(7,buf,len,s)) // speed [km/h]
                            printf("GPS Speed: %.1f\r\n", s);
#endif
#ifdef CELLOCATE
        if (mdmOk && (j++ == submitPeriod * 1000/wait)) {
            j=0;
            printf("CellLocate Request\r\n");
            /// mdm.cellLocRequest(sensorMask, submitPeriod-timeoutMargin, targetAccuracy);
            mdm.cellLocRequest(MDMParser::CELL_LOCATE, 15, 1, MDMParser::CELL_DETAILED, 1);
            cellLocWait = true;
        /// if (cellLocWait && mdm.cellLocGet(&loc)){
        if (cellLocWait && mdm.cellLocGetData(&loc)){
            printf("CellLocate position received, sensor_used: %d,  \r\n", loc.sensor );
            printf("  latitude: %0.5f, longitude: %0.5f, altitute: %d\r\n", loc.latitude, loc.longitude, loc.altitutude);
            if (loc.sensor == 1)
                printf("  uncertainty: %d, speed: %d, direction: %d, vertical_acc: %d, satellite used: %d \r\n", loc.uncertainty,loc.speed,loc.direction,loc.verticalAcc,loc.svUsed);
            if (loc.sensor == 1 || loc.sensor == 2)
                        "https://maps.google.com/?q=%.5f,%.5f", loc.latitude, loc.longitude);
        if (cellLocWait && (j%100 == 0 ))
            printf("Waiting for CellLocate...\r\n");
#endif
        Thread::wait(wait);
    printf ("GNSS Power Off\r\n");
    gps.powerOff();
    printf ("Modem Power Off\r\n");
    mdm.powerOff();
    return 0;
7 years, 3 months ago.
Hey U got any answer if you still able to see this quest?? I am facing same problem here.
