8 years, 10 months ago.
RTC problem with LPC1768
I'm a beginner with LPC1768, and from the datasheet I found that there's a RTC in it. And my problem is that if i want to use the internal RTC to get the real time, what code shall I write in compiler? Do I need to set the time and the date?
You need to do it like this: https://developer.mbed.org/handbook/Time, that uses the RTC. You do need to set the time, since it is just a simple counter in the end. So if you unplug your device, and also the battery backup voltage (the Vbat pin, typically not connected), it will lose its time.
