8 years, 9 months ago.
Connect a simple push button to Nucleo
Hi, I am a computer engineer and I am new with Nucleo. I ame building a simple system that reacts to a button push - it has to play a different .wav file for each of the 3 buttons we connect to it. The .wav is read from a memory card. I found an explanatio of how to connect Audio jack to Nucleo and how to connect the memory card. I am looking for explanation/connection circuit for a simple push button. Thanks! Tali
Please read this tutorial: https://learn.sparkfun.com/tutorials/switch-basics
I would recommend you get those to easy connection: Grove Button https://www.seeedstudio.com/Grove-Button-p-766.html Grove 4 Pin Female Jumper to Grove 4 pin Conversion Cable https://www.seeedstudio.com/Grove-4-pin-Female-Jumper-to-Grove-4-pin-Conversion-Cable-%285-PCs-per-PAck%29-p-1020.html
Best Regards
