8 years, 9 months ago.
Can you convert arduino code to mbed code ?
const int greenLEDPin = 9; const int blueLEDPin = 10; const int redLEDPin = 11; useful constants const int redSensorPin = A0; const int greenSensorPin = A1; const int blueSensorPin = A2;
int redValue = 0; int greenValue = 0; int blueValue = 0; variables to store the sensor readings as well as the light level of each LED int redSensorValue = 0; int greenSensorValue = 0; int blueSensorValue = 0;
void setup(){ Serial.begin(9600); setting the direction of the digital pins and setting up the serial port pinMode(greenLEDPin, OUTPUT); pinMode(blueLEDPin, OUTPUT); pinMode(redLEDPin,OUTPUT); }
void loop(){ redSensorValue = analogRead(redSensorValue); delay(5); reading the vlaue of each light sensor greenSensorValue = analogRead(greenSensorValue); delay(5); blueSensorValue = analogRead(blueSensorValue);
Serial.print("Raw Sensor Value \t Red:");
Serial.print(redSensorValue);
Serial.print("\t Green:");
report the sensor readings to the computer
Serial.print(greenSensorValue);
Serial.print("\t Blue:");
Serial.print(blueSensorValue);
redValue = redSensorValue/4; greenValue = greenSensorValue/4; Convert the sensor readings from a value between 0 - 1023 blueValue = blueSensorValue/4; to a value between 0 - 255
Serial.print("Mapped Sensor Values \t Red:"); Serial.print(redValue); Serial.print(" \t Green:"); report the calculated LED light levels Serial.print(greenValue); Serial.print("\t Blue:"); Serial.print(blueValue);
analogWrite(redLEDPin,redValue);
analogWrite(greenLEDPin, greenValue); Set the LED light levels
analogWrite(blueLEDPin, blueValue);
