8 years, 11 months ago.
Export project to GCC (arm embedded)
I can't select GCC(arm embedded) when attempting to export my C027 project. Is this a bug or a deficiency?
Hi Neil,
Thanks for getting in touch, at this moment there are issues with exporting from the online-IDE which is why you seeing the errors, this is being worked on but until then i can suggest using our offline build option mbed-cli.
This will allow you to everything in the online-IDE import libraries, compile etc and even export to the needed toolchain.
It is located here. https://github.com/ARMmbed/mbed-cli
After installing CLI The commands would look something like this to download a blinky example using lpc1768.
You have now compiled the program, to export follow below
  • $ mbed export -i uvision5 -m lpc1768
If you need anything else, let me know
Andrea, team mbed
so why was it broken in the first place? i need to export a project so i can compile locally like i have always done. Also noticed that NO export just the files to zip and none of the exports provide a makefile they are all commercial app project files. The only two exports that might be useful to me gcc codesourcery and cmis and neither work. why was a broken system deployed in the first place??? and how can we go back to the working system?
posted by Gary Matthews 17 May 2017
