8 years, 8 months ago.
Import mbed-dev to a stm32cube mx project
Hi, I am using Keil as an IDE and it work great for debugging mbed-os exported projects.
Currently I am working with a custom target, based on the NUCLEO-F446ZE, but with different clock settings. Since the custom board was clock-incompatible with the original target, and i needed usb-otg support, I was forced to start using stm32cubemx for generating startup code.
But most of my code for my application was developed during the prototyping stage using mbed-dev libraries and c++ classes, like Serial, InterruptIn, Ticker, and many others.
I tried many ways to import mbed-dev to a stm32cubemx generated project on Keil, but nothing works properly. I managed to compile the code with no errors, but after flashing, most of mbed objects don't work properly.
i suppose i should post code, or something that could help someone help me, but i am hopping that someone in here had this same problem and found a solution.
I have tried to approaches, but had no success. Approach 1:
- Generate a STM32cubemx project with all the peripherals and clock configs i need.
- Migrate the project form C to C++.
- Add USB suport as a CDC device. (Everything works till here)
- Import mbed-dev (minus the files that are already in the project).
- Add InterruprIn and wait_us calls to main()
After compiling and flashing, InterruptIn get stuck during initialization and wait_us() also get stuck.
Approach 2:
- Generate a mbed project (Blinky) and export it to mbed (works ok)
- Replace mbed-dev/targets/target_stm files with new ones.
Also interruptIn get stuck during initialization and wait_us() also get stuck.
It seems to me that something must be modified in the cube files to work with mbed-dev libraries. I have some ideas where to start looking, but I am hoping someone had this same problem in the past and knows how to deal with it.
Any help would be much appreciated.
As a side comment, mbed is a great tool for prototyping, but when moving forward to a custom-board as a final product, many issues arise. This is one of the many issued i had encountered when migrating from a development board to a custom-board. If i had the time to re-write the code that was written with mbed-dev and use raw HAL-CMSIS code, i would abandon mbed altogether.
Any comments or piece of advice on this would also be appreciated.
regards
Hello Guillermo,
You can add code snippets or files generated by the stm32cube mx to your mbed project. Have a look at the Internal_Temperature_F103RB demo and the CANnucleo library. You can also change the clock settings in your mbed application based on the code generated in frame of a stm32cube mx project. Have a look at the STM32F103C8T6_Hello demo and the mbed-STM32F103C8T6 library. But then, to avoid initialization issues, I recommend you to create your mbed objects in main after the system clock has already been set, as for instance in this STM32F103C8T6_ILI9341 demo.
Thanks Zoltan,
so far that approach is the one that has worked in most cases. But I still have to deal with outdated code in core include files in folder targets/target_stm/ that don't allow some snippets to work. Particularly I am trying to enable USB CDC, but on my board it only works with latest stm32cube libraries.
posted by 02 May 2017
