8 years, 11 months ago.
Help: Program compiles on server but not locally
Hi So i'm using a 3rd party lib that fails to compile under GCC_ARM but is fine in the online compiler.
Any ideas what i'm doing wrong. is there a setting on local compiler i need to use?
Cheers
Alex
Output from local compile: D:\work\mbed\mbed-assimilate-json>mbed compile Building project mbed-assimilate-json (K64F, GCC_ARM) Scan: . Scan: FEATURE_BLE Scan: FEATURE_COMMON_PAL Scan: FEATURE_LWIP Scan: FEATURE_UVISOR Scan: FEATURE_ETHERNET_HOST Scan: FEATURE_LOWPAN_BORDER_ROUTER Scan: FEATURE_LOWPAN_HOST Scan: FEATURE_LOWPAN_ROUTER Scan: FEATURE_NANOSTACK Scan: FEATURE_NANOSTACK_FULL Scan: FEATURE_THREAD_BORDER_ROUTER Scan: FEATURE_THREAD_END_DEVICE Scan: FEATURE_THREAD_ROUTER Scan: FEATURE_STORAGE Scan: mbed Scan: env Compile [ 4.3%]: at24mac.cpp Compile [ 4.5%]: MbedJSONValue.cpp [Error] MbedJSONValue.h@357,9: expected unqualified-id before '' token [Error] MbedJSONValue.h@357,0: expected ')' before '' token [Error] MbedJSONValue.cpp@244,1: expected '}' at end of input [Error] MbedJSONValue.h@355,116: expected unqualified-id at end of input [ERROR] In file included from .\MbedJSONValue\MbedJSONValue.h:38:0, from .\MbedJSONValue\MbedJSONValue.cpp:1: .\MbedJSONValue\MbedJSONValue.h:357:9: error: expected unqualified-id before '' token int getc() { ^ .\MbedJSONValue\MbedJSONValue.h:357:9: error: expected ')' before '' token .\MbedJSONValue\MbedJSONValue.cpp:244:1: error: expected '}' at end of input } ^ In file included from .\MbedJSONValue\MbedJSONValue.cpp:1:0: .\MbedJSONValue\MbedJSONValue.h:355:116: error: expected unqualified-id at end of input input(const char * first, const char * last) : cur_(first), end_(last), last_ch_(-1), ungot_(false), line_(1) {}; ^
[mbed] ERROR: "c:\python27\python.exe" returned error code 1. [mbed] ERROR: Command "c:\python27\python.exe -u D:\work\mbed\mbed-assimilate-json\mbed-os\tools\make.py -t GCC_ARM -m K64F source . build .\BUILD\K64F\GCC_ARM" in "D:\work\mbed\mbed-assimilate-json" -
NB source for MbedJSONValue is at https://developer.mbed.org/users/samux/code/MbedJSONValue/docs/tip/classMbedJSONValue.html
