8 years, 10 months ago.
W5500 with Nucleo-F103
Dear all,
I want to receive data via Ethernet on my F103 with W5500 shield. First I want to make a webserver and after that i want to add the functionality to receive the other data.
But i can't get my webserver working.. It's not getting the right ip adress, not via DHCP (tried a server on my PC and router), not with fixed ip addresses.
Is there anybody that can help me to solve this?
Thank you in advance!
Kind regards
This is a board combination that I use and do not see any particular issues. Can you be more specific about what is happening. Feel free to share your code that doesn't work...otherwise it's very difficult to guess the problem.
I tried several example projects and another shield, but they won't make the ethernet connection. My enc26j60 adapter is working, but the combination with W5500 doesn't like me.
Thank you in advance.
#include "W5500Interface/EthernetInterface.h"
#include "HTTPClient.h"
// EthernetInterface eth;
Serial pc(USBTX, USBRX);
pc.baud(115200);
wait(5);
printf("spi init\r\n");
SPI spi(PA_7, PA_6, PA_5); // mosi, miso, sclk
wait(1); // 1 second for stable state
EthernetInterface eth(&spi, PB_6, PA_9);//scs(D10), nRESET(PTA20)
printf("App Start\r\n");
const char * IP_Addr = "192.168.0.194";
const char * IP_Subnet = "255.255.255.0";
const char * IP_Gateway = "192.168.0.1";
eth.init(); //Use DHCP
wait(1);
eth.connect();
printf("IP Address is %s\r\n", eth.getIPAddress());
char str[512];
char get_msg[512]= "http://api.openweathermap.org/data/2.5/weather?q=Seoul";
HTTPClient http;
printf("Send get Message to openeathermap.org\r\n");
printf("msg : %s\r\n",get_msg);
int ret = http.get(get_msg, str, sizeof(str));
if(!ret)
printf("\r\nPage fetched successfully - read %d characters\r\n", strlen(str));
printf("Result: %s\r\n", str);
else
printf("Error - ret = %d - HTTP return code = %d\n", ret, http.getHTTPResponseCode());
Hello Peer,
As I know the W5500 does not have a built in MAC number. So you have to set up one by yourself. You can test this demo:
https://developer.mbed.org/users/hudakz/code/WebSwitch_WIZ550io/
To use W5500 uncomment line #49. The MAC number must be unique within the connected network so modify it as appropriate.
Here is a short code to get the mbed internal mac address
extern "C" void mbed_mac_address(char *mac);
char mac[6];
mbed_mac_address(mac);
printf("MAC Address: %02x:%02x:%02x:%02x:%02x:%02x\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
