8 years, 11 months ago.
how to use HAL commands??
I have CANBUS working under HAL drivers in uV5 but how can I add these three components ?
How to translate this:
-2- Configure the CAN Filter ######### sFilterConfig.FilterNumber = 0; sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK; sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT; sFilterConfig.FilterIdHigh = 0x400 << 5; 11-bit ID in top bits sFilterConfig.FilterIdLow = 0x0000; sFilterConfig.FilterMaskIdHigh = 0x600 << 5; resolves as 0x01xx sFilterConfig.FilterMaskIdLow = 0x0000; sFilterConfig.FilterFIFOAssignment = 0; sFilterConfig.FilterActivation = ENABLE; sFilterConfig.BankNumber = 0;
if (HAL_CAN_ConfigFilter(&hcan, &sFilterConfig) != HAL_OK) { Filter configuration Error Error_Handler();
sprintf(console::string,"Can Filter configuration Error\n\r"); console::io.puts(console::string); }
and translate this:
HAL_CAN_ENABLE_IT (&hcan, CAN_IT_FMP1); HAL_CAN_ENABLE_IT (&hcan, CAN_IT_FMP0);
and this:
void CEC_CAN_IRQHandler(void) { /* USER CODE BEGIN CEC_CAN_IRQn 0 */ CAN_IRQFlag = true; checkCanRxFifos(); receive CAN messages before HAL sees them.
/* USER CODE END CEC_CAN_IRQn 0 */ HAL_CAN_IRQHandler(&hcan); /* USER CODE BEGIN CEC_CAN_IRQn 1 */
/* USER CODE END CEC_CAN_IRQn 1 */ }
Hello Nick,
Have a look at the CANnucleo library. It has been implemented by calling HAL commands.
Hi, I used your code CANnucleo (you have a few renditions) successfully, but I had to add this to make the RX interrupt work.
void onMsgReceived() { msgAvailable = true; ++Counter; can.read(rxMsg); }
if (msgAvailable){ msgAvailable = false; setCursor(4,60); Usart1.printf("Can msgAvailable %d \r\n",Counter);
led = ON; turn the LED on setCursor(0,0); Usart1.printf("CAN message received\r\n"); printMsg(rxMsg);
Filtering performed by software: if(rxMsg.id == RX_ID) { rxMsg >> counter >> voltage; extract data from the received CAN message Usart1.printf(" counter = %d\r\n", counter); Usart1.printf(" voltage = %e V\r\n", voltage); timer.start(); transmission lag } }
thanks for the support. Now I will work on loading the RxTables under interrupt so we don't lose any frames. then the Tx...
posted by Nick Marsh 10 Apr 2017
Hi Nick,
Glad to be of help. Zoltan
posted by Zoltan Hudak 10 Apr 2017
