9 years ago. This question has been closed. Reason: Duplicate question
Serial2 not working on Nucleo L476RG
I am currently Arduino users and I was able to communicate with Ublox Neo-6M module successfully with Arduino Uno R3 board using TinyGPS++ Arduino AVR library. Now, my requirements are changed and one of them performance and memory requirements hence I have selected Nucleo L476RG board as it supports mebd library.
I was able to successfully testing , Digital I/0, PWM, ADC, DAC, etc., but I could not get Serial2 (PA_2 and PA_3) connecting Ublox module using mbed library.
Also note that Ublox connected via separate 3.3 V power supply with common ground.
I have attached the code for your reference.
Appreciate if you could assist on how to troubleshoot this issue as I am not sure problem with Nucleo board or anything else.
mbed Code
#include "Ublox.h"
DigitalOut myled(LED1);
Serial pc(USBTX, USBRX);
Serial gps(PA_2, PA_3); // tx, rx
Ublox ublox;
void processGPS()
if(gps.readable()) {
char c = gps.getc();
ublox.encode(c);
pc.baud(9600);
pc.format(8,SerialBase::None,1);
myled=1;
gps.attach(&processGPS, Serial::RxIrq);
pc.printf("lat,");
pc.printf("long,");
pc.printf("time\r\n");
pc.printf("%f,", ublox.latitude);
pc.printf("%f,", ublox.longitude);
pc.printf("%d/%d/%d - %d:%d:%d\r\n",
ublox.datetime.year,
ublox.datetime.month,
ublox.datetime.day,
ublox.datetime.hours+8,
ublox.datetime.minutes,
ublox.datetime.seconds);
myled = !myled;
wait(1);
9 years ago.
Unless you are using the BufferedSerial library (here at mbed) I believe you are not allowed to call getc() within the interrupt handler. Alternatively you can set a global volatile variable and do your getc in the main while loop.
