8 years, 11 months ago.
C++ class initialization orders ?
I am evaluating a Semtech LoRa code for its SCPI command parser. When I build the code, it throws 4 warnings:
sx127x.cpp
SX127x::SX127x(PinName mosi, PinName miso, PinName sclk, PinName cs,
                PinName rst, PinName dio_0, PinName dio_1) :
                m_spi(mosi, miso, sclk),
								m_cs(cs),
								reset_pin(rst),
								dio0(dio_0), dio1(dio_1)
    reset_pin.input();
    m_cs = 1;
    m_spi.format(8, 0);
    m_spi.frequency(3000000);
    init();
warnings
compiling sx127x.cpp...
SX127x/sx127x.cpp(22): warning:  #1299-D: members and base-classes will be initialized in declaration order, not in member initialisation list order
  								m_cs(cs),
SX127x/sx127x.cpp(24): warning:  #1299-D: members and base-classes will be initialized in declaration order, not in member initialisation list order
SX127x/sx127x.cpp(25): warning:  #1361-D: function "mbed::FunctionPointerArg1<R, void>::FunctionPointerArg1(R (*)()) [with R=void]" (declared at line 67 of "mbed/./platform/FunctionPointer.h") was declared "deprecated"
SX127x/sx127x.cpp: 4 warnings, 0 errors
linking...
Program Size: Code=55880 RO-data=6264 RW-data=260 ZI-data=2788
What do they mean? How can I remove these warnings ? Should I declare DigitalOut/DigitalIn for these pins (CS/RST/DIO0/DIO1) before these constructor ?
In principle the warning isn't really important in this case, however of course it is nicer if it compiles without warnings. If I remember correctly you need to declare them in your .h file in the same order as you put them in your .cpp file in line 3-6 here in your piece of code.
Hi Kai,
You can read this item from the C++ FAQ. Base class and data member order initialization follow declaration order, not constructor initialization list order:
class Foo;
class Bar;
Foo make_foo();
Bar make_bar(const Foo& f);
struct Qux {
    // not valid, _bar will be initialized before _foo with a not initialized
    // instance of _foo
    Qux() : _foo(make_foo()), _bar(make_bar(_foo)) { }
private:
   Bar _bar;
   Foo _foo;
