9 years ago.
mbed IDE compatibility
Dear all,
I experience a few problems with the mbed and Atmel Studio, is there anyone who is using the Atmel Studio?
Thank you in advance!
Best regards,
Ilias
EDIT: First of all Atmel Studio creates a file in.cpp (which is not found), I replaced it with the main.cpp Then, when I tried to compile the code I received the following error: "Error 1 mbed_config.h: No such file or directory"
EDIT 2: I am just creating a simple blinky based project in the online compiler and then I export it for the Atmel Studio.
"few problems" More details please.
posted by Mark Peter Vargha 03 Apr 2017
9 years ago.
The exports never seem to work right off and require a lot of tweaking of search paths and settings. I believe mbed_config.h is generated as part of the export. Here is one from a recent project as an example. Does this have everything you need? I don't know.
// Automatically generated configuration file.
// DO NOT EDIT, content will be overwritten.
#ifndef __MBED_CONFIG_DATA__
#define __MBED_CONFIG_DATA__
// Configuration parameters
#define MBED_CONF_CORE_STDIO_BAUD_RATE        9600//921600 // set by library:core
#define MBED_CONF_NSAPI_PRESENT               1    // set by library:nsapi
#define MBED_CONF_RTOS_PRESENT                1    // set by library:rtos
#define MBED_CONF_CORE_STDIO_CONVERT_NEWLINES 0    // set by library:core
// Macros
#define UNITY_INCLUDE_CONFIG_H                     // defined by library:utest
// RTOS Parameters
#define OS_TASKCNT         20
#endif
9 years ago.
mbed_config.h missing from exported project is a known bug. https://github.com/ARMmbed/mbed-os/issues/4075
Here are some config files, you can create one for your project from these.
STM Discovery, no OS
#define MBED_CONF_PLATFORM_STDIO_BAUD_RATE          9600 // set by library:platform
#define MBED_CONF_PLATFORM_DEFAULT_SERIAL_BAUD_RATE 9600 // set by library:platform
#define MBED_CONF_PLATFORM_STDIO_FLUSH_AT_EXIT      1    // set by library:platform
#define MBED_CONF_PLATFORM_STDIO_CONVERT_NEWLINES   0    // set by library:platform
#endif
STM32F103 Nucleo with OS
#define MBED_CONF_FILESYSTEM_PRESENT                1    // set by library:filesystem
#define MBED_CONF_EVENTS_PRESENT                    1    // set by library:events
// Macros
#endif
Hello, thank you very much for your reply. So just to get the point the config file is hardware dependent, for example I am using an Atmel R21 xplained-xpro board. Furthermore, you mention with/without OS, the exported project doesn't contain the OS(net stack,etc)? Thank you in advance!
posted by ILIAS SEITANIDIS 17 Apr 2017
9 years ago.
Finally the export to Keil uV5 works...
I use the STM32F091, so the community license works upto 256Kbytes.
