8 years, 6 months ago.
Interrupt in problem with sensor
I want to read an Ultrasonic sensor srf05, but i don't understand why my program doesn't work. Pin are good, but the "echo.rise(...)" doesn't detect anythink.
Device: LPC1768
Thank
main.cpp
DigitalOut trigger(p24);
InterruptIn echo(p23);
Serial pc(USBTX, USBRX);
int distance;
Timer t;
Ticker mesure;
void mesurer()
    trigger=1;      //Send the trigger signal to get measurment
    wait_us(10);
    trigger=0;
    wait_us(10);
void start_timer()
    t.reset(); // rising edge detected
    t.start();  // start measurment
void lecture_distance()
    t.stop(); // falling edge detected
    distance=(t.read_us()/58);
    pc.baud(9600);
    mesure.attach(&mesurer,0.5); //10 mesures par seconde
    echo.rise(&start_timer);
    echo.fall(&lecture_distance);
    while(1){
        printf("Distance %d cm\n\r", distance);
Hello Emma,
I'm not sure but most likely the serial terminal on your PC is overwhelmed with data sent by the printf function in the while loop. Try to modify the code as follows:
int         distance;
Timer       t;
Ticker      mesure;
void mesurer(void) {
    trigger = 1;    //Send the trigger signal to get measurement
    wait_us(10);
    trigger = 0;
    //wait_us(10);
void start_timer(void) {
    t.start();      // start measurement
void lecture_distance(void) {
    distance = (t.read_us() / 58);
int main(void) {
    pc.baud(9600);
    mesure.attach(&mesurer, 0.5);   //two measurements per second
    while(1) {}
Thank for your answer, but it's not the prinf, i have change my mbed and it's work...
posted by emma debar 05 Apr 2017
