8 years, 11 months ago.
mbed os build options
How can we build for example, only our application source files with an option and not the rest of the project?, for example
./project/ /mbed-os/ /source/ only this one should be built with an extra option
You can't. The profiles are applied to entire application. I would like to know more about your use case.
My aim is to integrate gprof analyzer to my project, but I don't want to analyze the whole project, I juste want to profile my source directory. I did succeed to compile my source directory alone with -pg option by modifying the build script, the gcc.py exactly and add the option for gprof. If I try to compile the whole project, gprof source code will be compiled with -pg option, which means gprof will profile itself, this causes an infinite loop.
posted by 31 Mar 2017
