8 years, 6 months ago.
Promblem with ACD52832 from Aconno
During playing around with the Aconno board I encountered a problem with the onboard display. With mbed-os version 2 it works quite well. With mbed-os Version 5 it doesn't. (I used the introduction program) Does anybody have a solution for that or what am I doing wrong ?
Thanks in advance for any idea !
Hi, can you please describe a bit more about the problem. Also which part did you use from mbed-os5? Regards.
posted by Jurica Resetar 29 Mar 2017
I simply took the ACD52832_ePaper example program and compiled it and that works well. That means, the display showed the correct content. Than I exchanged the mbed library (=OS2) by mbed-os library (=OS5) and the display did not work. From my point of view, the display driver for the build in display of the aconno board does not work together with mbed OS5. Regards.
posted by e s 30 Mar 2017
Hi, yes, that is the problem. We are working on a new version of the EPD library that should support os-5. Please stay tunned. I will post source to that example here as soon as we develop the solution.
posted by Jurica Resetar 30 Mar 2017
Hi there =) We have tested our ePaper with mbed-os (v5) and it works fine. Can you provide us with your source so we can check where's the problem? Regards, Jurica, aconno team.
posted by Jurica Resetar 12 Apr 2017
