8 years, 12 months ago.
Getting code built with GCC4MBED to run on custom target
I've developed a custom target and can use the online tool to build a blinky app. I program the microcontroller by copying the bin file onto the mounted USB volume. It blinks.
I take the same code, run "make clean lpc11u37", copy the resulting bin file with the same method to the microcontroller but no blinky.
For the online compiler, lacking an LPC11U37, I build with LPC11U24. For GCC4MBED, I made changes to support the LPC11U37FBD48/401 which is the part I have designed in.
As this is my first offline attempt with GCC tools, I think I must be missing something. Any tips?
Thanks.
C:\gcc4mbed-b0e31ff\samples\blinky_gcc_arm_lpc11u24>make clean lpc11u37 Cleaning klc_blinky/LPC1768 Cleaning klc_blinky/LPC11U37 Compiling main.cpp Compiling ../../src/gcc4mbed.c Linking LPC11U37/klc_blinky.elf Extracting LPC11U37/klc_blinky.bin Extracting LPC11U37/klc_blinky.hex Extracting disassembly to LPC11U37/klc_blinky.disasm text data bss dec hex filename 3216 112 64 3392 d40 LPC11U37/klc_blinky.elf
Hello Kevin,
posted by Zoltan Hudak 29 Mar 2017Unfortunately I'm not familiar with GCC4MBED so I'm not able to help you with that, but do you have any specific reason to use GCC4MBED? If I understand correctly you replaced the binary mbed library in your project with source files and added a custom target support. So why don't you simply export your working project from the online compiler (Ctrl+E) for the GCC (ARM embedded) toolchain and then compile it offline?
