8 years, 11 months ago.
MODSERIAL - RX Interrupt
I have this simple code and I would like to use MODSERIAL RX Interrupt. When I start up my board, RX Interrupt does not work and i do not know why. Could You help me ?
#include "USBSerial.h"
#include "MODSERIAL.h"
#include "at25sf041.h"
#include "string"
//#include "rtos.h"
string a;
DigitalOut LedStatus(P0_13);
DigitalOut LedBattery(P0_14);
DigitalOut USB_connect(P0_6);
AnalogIn ain(P0_11);
USBSerial usb(0x1f00, 0x2012, 0x0001, false);
DigitalIn Vbus(P0_3);
AT25SF041 memory(P0_9, P0_8, P0_10, P0_15);
MODSERIAL uart(P0_19, P0_18);
InterruptIn GPS_fix(P0_17);
volatile bool newline_detected = false;
char tmp[10];
void Rx_interrupt(MODSERIAL_IRQ_INFO *q)
    MODSERIAL *serial = q->serial;
    if ( serial->rxGetLastChar() == '\n') {
        newline_detected = true;
    LedBattery = !LedBattery;
void toogle()
    LedStatus = !LedStatus;
void usb_rx()
    //tmp = usb.getc();
    USB_connect = 0;
    GPS_fix.rise(&toogle);
    uart.baud(9600);
    uart.attach(&Rx_interrupt, MODSERIAL::RxIrq);
    while (1) {
        //  if (usb.readable())
        //   LedStatus = !LedStatus;
        //  tmp = usb.getc();
//  if (usb.readable()){
//  usb.scanf("%s", a);
//  usb.printf("%s", a);
        if (a == "l0" && newline_detected) {
            char c;
            while((c = uart.getc()) != '\n') {
                usb.putc(c);
            usb.printf("\r\n");
So LedBattery does not toggle? Are you sure actual data arrives on that serial connection?
posted by Erik - 22 Mar 2017
LedBattery toggle only once. When I remove the condition a=="10" then the code works. There is GPS module on that UART and data arrives every one second.
posted by Peter Augustin 22 Mar 2017
Hello, Probably I found out problem. The problem is RX buffer because if RX buffer is full then interrupt is stopped. How can I clean RX buffer ?
posted by Peter Augustin 23 Mar 2017
