8 years, 11 months ago. This question has been closed. Reason: Off Topic
Exporting
why do i get error everytime i try to export to keil version. but no problem export to openstm32 or coocox
Hi Tonny,
Thanks for getting in touch, at this moment there are issues with exporting from the online-IDE which is why you seeing the errors, this is being worked on but until then i can suggest using our offline build option mbed-cli.
This will allow you to everything in the online-IDE import libraries, compile etc and even export to the needed toolchain.
It is located here. https://github.com/ARMmbed/mbed-cli
After installing CLI The commands would look something like this to download a blinky example using lpc1768.
- $ cd "TO DESIRED DIRECTORY"
- $ mbed import https://developer.mbed.org/teams/mbed-os-examples/code/mbed-os-example-blinky/
- $ cd "TO NEW CREATED FOLDER"
- $ mbed deploy
- $ mbed compile -t GCC_ARM -m lpc1768
You have now compiled the program, to export follow below
- $ mbed export -i uvision5 -m lpc1768
If you need anything else, let me know
Andrea, team mbed
