9 years ago.
MBED file doesn't export program to desktop (KEILv5)
Tried to export my ready made program for KEIL uVision5 as its Export toolchain. But in my case, this pop-up dialog box appears.
/media/uploads/czaleu/capture.png
It worked few days ago until this error occured.
Need help, thanks. :)
8 years, 12 months ago.
Hi Zaleu,
Thanks for getting in touch, at this moment there are issues with exporting from the online-IDE which is why you seeing the errors, this is being worked on but until then i can suggest using our offline build option mbed-cli.
This will allow you to everything in the online-IDE import libraries, compile etc and even export to the needed toolchain.
It is located here. https://github.com/ARMmbed/mbed-cli
After installing CLI The commands would look something like this to download a blinky example using lpc1768.
You have now compiled the program, to export follow below
  • $ mbed export -i uvision5 -m lpc1768
If you need anything else, let me know
Andrea, team mbed
