9 years ago.
I have to read the AMt20 encoder spi with mbed but mi code doen't work
- include "mbed.h"
SPI spi(PTD2, PTD3, PTD1); mosi, miso, sclk
DigitalOut cs(PTD0);
Serial pc(USBTX, USBRX); tx, rx
int main(void) {
PwmOut rled(LED1); PwmOut gled(LED2);
PwmOut bled(LED3);
pc.baud(115200);Set baudrate here.
Chip must be deselected
Setup the spi for 8 bit data, high steady state clock,
second edge capture, with a 1MHz clock rate
spi.format(8,3);
spi.frequency(500000);
Select the device by seting chip select low
cs = 0;
Send 0x8f, the command to read the WHOAMI register
spi.write(0x8f);
Send a dummy byte to receive the contents of the WHOAMI register
uint8_t whoami = spi.write(0x00);
Deselect the device cs = 1;
while(1)
{ cs = 0;
whoami = spi.write(0x10); read position rd_pos
cs = 1;
if (whoami==0xA5)
{ cs=0;
spi.write(0x00);
cs=1;
else
{ if(whoami==0x10)
cs=0;
uint8_t who1=spi.write(0x00);
pc.printf(whoami);
cs=1;
wait_us(20);
cs=0;
uint8_t who2=spi.write(0x00); cs=1; uint8_t d = who1 << 8|who2;
float m=map(d,0, 4096,0,360);
(long x, long in_min, long in_max, long out_min, long out_max)
int m = ((d*360)/4096);
int n= 360-m;
rled = 1.0f - m;
pc.printf("grados: %d, n: %d\n", m, d); } }
wait_ms(5); }
Hi, did you find a solution. Beacause I can't get it to work
posted by Robin Galipeau 19 Jun 2018
