9 years ago.
Error Exporting to Keil
Hi, I'm trying to export my proyect to Keil uVision 5, but when I select my target (NUCLEO-446ZE), the toolchain (uVision 5) and I clic on export I get the error: 'An error occured during export. Please contact support.' How can I fix it? Do I have to configure something? thank you for your time.
Same for me. Nucleo F103
posted by Mark Peter Vargha 22 Mar 2017
9 years ago.
Hi Javier,
Thanks for getting in touch, at this moment there are issues with exporting from the online-IDE which is why you seeing the errors, this is being worked on but until then i can suggest using our offline build option mbed-cli.
This will allow you to everything in the online-IDE import libraries, compile etc and even export to the needed toolchain.
It is located here. https://github.com/ARMmbed/mbed-cli
After installing CLI The commands would look something like this to download a blinky example using lpc1768.
You have now compiled the program, to export follow below
  • $ mbed export -i uvision5 -m lpc1768
If you need anything else, let me know
Andrea, team mbed
The problem is still present!
posted by bruno LARNAUDIE 16 Oct 2017
