9 years ago.
How to change the description of the mBed library that is already published?
We have published a library https://developer.mbed.org/teams/IBM_IoT/code/IBMIoTF/wiki/Homepage sometime back and would like change the description a bit - I tried modifying it from the mBed compiler and pushed the changes, But could not successfully modify it. Can you please help?
9 years ago.
Hello Sathiskumar,
Go to the repository page of your library (https://developer.mbed.org/teams/IBM_IoT/code/IBMIoTF/) and open the "Admin settings" tab (it's the last one). That will enable you to modify the Repository name, Description, Tags and other attributes.
If you would like to modify the Wiki page then click on the "Edit repository home page" link.
