8 years, 10 months ago.
KL43Z DAC speed too slow
Hi everyone i am new to mbed (only few days).
Currently using the KL43Z try to generate Ramp waveform from DAC oupt. The DAC is 12 bit. However, if i do 100 steps from 0 to 3.3V. it gives nice waveform but it is too slow the frequency only 537.6Hz. For the project i want to goes to 3MHz.
there are some question i would like to ask:
- Q 1.the frequency was limit by the CPU clock frequency? but it is 48MHz.
- Q 2.if direct write to the register, will it be faster? can i use calculation formula to see how fast it can be?
- Q 3. rewrite the library to get more efficiency ?
- Q 4. other suggestion ?
Thank you very much
DAC ramp waveform
#include "AnalogOut.h"
AnalogOut dac(PTE30);// dac=0.0f, 0=0V, 1.0f=3.3V, 0.5f= 1.65V
printf("SystemCoreClock = %d Hz\n", SystemCoreClock);
while (1) {
//incarse the voltage steadily from 0V to 3.3V
for (float i = 0; i<=1; i +=0.1){
dac= i;
//deacrease the voltage steadily from 3.3V to 0V
for (float j = 1; j>=0; j-=1){
dac= j;
