8 years, 10 months ago.
Exporting error
Export to Keil 5.0 of mbed LCP1768 fails.
It says "contact support"
So, here i am.
What to do next.
Hi Evert,
Thanks for getting in touch, at this moment there are issues with exporting from the online-IDE which is why you seeing the errors, this is being worked on but until then i can suggest using our offline build option mbed-cli.
This will allow you to everything in the online-IDE import libraries, compile etc and even export to the needed toolchain.
It is located here. https://github.com/ARMmbed/mbed-cli
After installing CLI The commands would look something like this to download a blinky example using lpc1768.
- $ cd "TO DESIRED DIRECTORY"
- $ mbed import https://developer.mbed.org/teams/mbed-os-examples/code/mbed-os-example-blinky/
- $ cd "TO NEW CREATED FOLDER"
- $ mbed deploy
- $ mbed compile -t GCC_ARM -m lpc1768
You have now compiled the program, to export follow below
- $ mbed export -i uvision5 -m lpc1768
If you need anything else, let me know
Andrea, team mbed
Is this Error still valid? I'm having similar kind of issue with my mbed online environment?
Also, How can I export my own projects with your guides as my project address is like this
https://developer.mbed.org/compiler/#nav:/EclipseExportHarjoitus;
And if I'll try to make import I'll get this error:
C:\Program Files (x86)\GNU Tools ARM Embedded\5.4 2016q3>mbed import https://developer.mbed.org/compiler/#nav:/EclipseExportHarjoitus;
[mbed] ERROR: Invalid revision (nav:/EclipseExportHarjoitus;)
Br, Arto
posted by 01 Aug 20178 years, 6 months ago.
Sorry, I pasted wrong lines from the Console. Here is the current problem with my own projects.
mbed import https://developer.mbed.org/compiler/#nav:/EclipseExportHarjoitus [mbed] Importing program "EclipseExportHarjoitus" from "https://developer.mbed.org/compiler/#nav:/EclipseExportHarjoitus" at latest revision in the current branch fatal: unable to update url base from redirection: asked for: https://developer.mbed.org/compiler/#nav:/EclipseExportHarjoitus/info/refs?service=git-upload-pack redirect: https://developer.mbed.org/accounts/login/?next=%2Fcompiler%2F unknown exception encountered, please report by visiting https://mercurial-scm.org/wiki/BugTracker
So it seems like this is somehow related to login?
Br,Arto
