9 years ago.
i'mm using STM32f103, i can't able to read data from an i2c eeprom,can anyone help me out?
#define eep_add ((uint8_t) 0x50<<1)
//#define eep_add (0xA0)
I2C i2c(PB_9, PB_8);
Serial pc(PA_2, PA_3);
char *data;
char buf[40]="hello ,welcome to asdfghjkloifnet";
i2c.frequency(100000);
while(1){
char cmd[sizeof(buf)+2];
cmd[0]=0x00>>8;
cmd[1]=0x00&0xFF;
for (int i=0;i<sizeof(buf);i++){
cmd[2+i]=buf[i];
i2c.write(eep_add,cmd,2+sizeof(buf));//write
wait(0.1);
cmd[0]=0x00>>8;
cmd[1]=0x00&0xFF;
i2c.write(eep_add,cmd,2,true);
i2c.read(eep_add,data,sizeof(buf));//read
pc.printf("%s\n",data);
wait(0.01);
9 years ago.
There are some problems with the code:
You declared
char *data;
and later on you read some data from the eeprom to store at that data pointer. However, there is no free memory allocated to the pointer and that may lead to undefined results. Either use malloc or replace the pointer by a static array same as for cmd.
Also note that when using printf for a string the string data must have a '0' as last entry.
