9 years, 1 month ago.
Is STM32F407G-DISC1 ever going to be supported on Mbed?
I've got STM32F407G-DISC1 board that says it is Mbed enabled? But when I searched for the platform on mbed I didn't get any. A little more search revealed that this platform is not supported on Mbed and users have been questioning this from past several months/few years. So Just wanted to know if Mbed ever plans to support this platform? If not , why give "Mbed enabled" label to STM32F407G?
8 years, 7 months ago.
Doesn't look like it, does it? Still, they've got your money.
The Arch Max Pro uses the STM32F407VE. Select that platform and you can at least use the online compiler and mbed libs for the F407VE. You should be able to update the firmware on the STLINK part of the Disco board just like for any other mbed nucleo and that should make the drag-drop programming feature available. Just be aware that the flash memory size is not the same and you cant use all of it until the Disco is fully supported: the F407VE has 512K, the F407VG has 1M.
