9 years, 1 month ago.
Trouble communication SPI
Hello, i want i send voltage to a component, which is regulated thanks to the AD5668. I wrote this code, but when i mesure the voltage, it kepps the same. Here is the code i wrote, maybe you could help me finding what's wrong :) Thanjks, Yann
#include "limits.h"
Serial pc(USBTX, USBRX);
SPI spi(PA_7, PA_6, PA_5); // mosi, miso, sclk
DigitalOut cs(PA_4);
    int rep =0;
    int bit32[32];
    int ch;
    int choix;
    // Chip must be deselected
    // Setup the spi for 8 bit data, high steady state clock,
    // second edge capture, with a 1MHz clock rate
    spi.format(16,1);
    spi.frequency(1000000);
//-----------------------Conversion de l'entier en 16 bits----------------------
 long int decimalNumber,remainder,quotient;
    int i=1,j,temp;
    char hexadecimalNumber[100];
    pc.printf("Ecrire dans le registre ADC(1)\n\n");
    pc.printf("Mettre a jour le registre ADC(2)\n\n");
    pc.printf("Ecrire et mettre a jour le registre ADC(3)\n\n");
    pc.printf("Mise sous tension ou hors tension(4)\n\n");
    pc.printf("Reinitialiser la mise sous tension (5)\n\n");
    scanf("%d",&ch);
       switch(ch) {
        case 01:
            pc.printf("Quel pourcentage de voltage (0-65535) ?\n");
    scanf("%ld",&decimalNumber);
    quotient = decimalNumber;
    while(quotient!=0){
         temp = quotient % 16;
      //To convert integer into character
      if( temp < 10)
           temp =temp + 48;
      else
         temp = temp + 55;
      hexadecimalNumber[i++]= temp;
      quotient = quotient / 16;
    pc.printf("Equivalent hexadecimal value of decimal number %d: ",decimalNumber);
    for(j = i -1 ;j> 0;j--)
     { pc.printf("%c",hexadecimalNumber[j]); }
    // Select the device by seting chip select low
     cs = 0;
    rep = spi.write(0x00FFFFF0);
    wait(0.5);
     cs=1;
     pc.printf("\n rep: %d \n",rep);
    break;
    case 02:
     cs=0;
     rep = spi.write(0x01F00000);
      wait(0.5);
     cs=1;
     pc.printf("\n rep2: %d \n",rep);
     pc.printf("Modification effectuee \n");
     break;
     case 03:   pc.printf("Quel pourcentage de voltage (0-65535) ?\n");
    while(quotient!=0){
      if( temp < 10)
           temp =temp + 48;
      else
         temp = temp + 55;
     cs = 0;
     spi.write(0x0);
    rep = spi.write(0x02FFFFF0);
    wait(0.5);
     cs=1;
    break;
    case 04:  pc.printf("Souhaitez vous une mise en tension(1) ou hors tension (2) ?\n");
            scanf("%d",&choix);
            if (choix == 1) {
                pc.printf("bien recu m\n");
           else if (choix == 2) {
                pc.printf("bien recu h\n");
            } else {
                pc.printf("Commande non reconnue\n");
            break;
     default: break;
/media/uploads/yanndb/capture1.png /media/uploads/yanndb/capture2.png
Here is the method to write to the AD. Do we agree that 0x02FFFFF0 should set the maximum voltage value et apply it directly ?
I just tried to mesure the voltage again and by changing the lines, i succeeded in getting a 7.12V voltage (started at 1). But i sent the maximum 16 bit value (FFFF) and it doesn't get me the maximum voltage, why ?
     cs = 0;
     spi.write(0x02);
     spi.write(0xFF);
     spi.write(0xA5);
     spi.write(0xF0);
    //wait(0.5);
     cs=1;
posted by Yann De Baudus 09 Mar 2017
You need to break your write up into two 16-bit transactions, or four 8-bit transactions in order to shift all 32 bits required. Make sure you shift the most significant byte or word first. (EDIT: I see you are trying something like this. Make sure you set the format back to 8 bits though if you are doing 4 transactions)
Thank you for your answer as you said, i tried it and it seems to work, but nos as correctly as it should ! How do you make sure you shift the most significant byte or word first ? And do i have to set the format at 16 or 32 ?
I would keep the format as 8 bit
spi.format(8,1);
and then shift the value out byte by byte such as
unsigned int val = 0xAABBCCDD; //whatever your 32-bit value to be written is
spi.write((uint8_t)val>>24);
spi.write((uint8_t)val>>16)
spi.write((uint8_t)val>>8);
spi.write((uint8_t)val);
I have not looked at your algorithm in detail but make sure you follow all of the required initialization in the datasheet.
Bill
posted by Bill Bellis 10 Mar 2017
So i just tried your method, and it doesn't seem to work, the voltage is still the same ? Is it possible to do it like below ?
spi.write((uint16_t)val>>16);
     spi.write((uint16_t)val);
So i choose format (16,1) Plus, do i have to send bits in order to make the AD understand i want to "talk" to him before sending bit stream ? I am a bit confused
posted by Yann De Baudus 10 Mar 2017
The code above is very hard to read and understand. Please use the <<code>> and <</code>> tags to post your code.
Looks like you are setting up SPI in 16 bit mode
spi.format(16,1);
However, you send values as 32 bit. The SPI write will truncate that to the least significant 16 bits.
//Select the device by seting chip select low
cs = 0;
wait(0.5);
cs=1;
Thank you for your answer, i corrected it, but the datasheet says it is a 16 bits SPI voltage output, BUT they ask me 32 bits to communicate with the AD5668 (4 useless, 4 command, 4 adress, 16 instruction, 4 useless again) :/
