9 years ago.
I2C not functioning Nucleo L476RG
Im trying to connect a Nucleo L476RG to a PCF 16x2 LCD
Connections aside I cant seem to setup the I2C whatsoever.
Using an I2C Scanner sketch with or without external pull-up resistors the SDA and SCL lines just sit at 3v3
Scanner code 1
I2C i2c(I2C_SDA, I2C_SCL); // sda, scl
pc.printf("RUN\r\n");
for(int i = 0; i < 128 ; i++) {
i2c.start();
if(i2c.write(i << 1)) pc.printf("0x%x ACK \r\n",i); // Send command string
i2c.stop();
Scanner code 2
char data = 0x00;
for (int i = 0; i<128;i++) {
if (i2c.write(i,&data,1) == 0)
pc.printf("0x%02x ACK\r\n",i);
I am new to MBed and so far I seem to be struggling.
Any help appreciated
Andy
9 years ago.
Hi Andy,
Please remove the calls to "i2c.start()" and "i2c.stop()" in "Scanner code 1". "i2c.write()" will take care of the start and stop steps for you. Do you see any data after making that change?
Also, not sure if "Scanner code 2" is the thing receiving the data or the second block of code you tried. It looks better but it's also missing the declarations of I2C and Serial. Though it wouldn't build at that point.
Let me know what you find!
Thanks, Brian
Hi Brian, thanks for that, have a look here at a later posted question of mine for the solution I found https://developer.mbed.org/questions/77345/TextLCD-PCF8574-Backpack-Nucleo-L476RG/
posted by 18 Mar 2017
