9 years, 1 month ago.
maxrefdes100 / HSP/ hsensor connection issue
there are 2 boards and how to right connect them to GUI.
Here are some basic connecting actions before you start clicking anything on PC,
if you are checking on Health Sensor Platform GUI, please
- 2 ways of connection. Both of them work good
- a). connect the sensor board to PC with a USBtype-C connector, or
- b). plug a micro-USB cabled into the device connector on the HDK
- Press and hold the only button on the sensor board for about half a second to wake the PMIC and turn on the board.
- Checking drivers on PC as guided on site
- https://www.maximintegrated.com/en/design/reference-design-center/system-board/6312.html/tb_tab1/#instructions (Tips: Find words "Quick Start Guide for PC Application" on this page where you may find the starting steps)
if you are going to program on this mbed device, please
- Connect Connect the HDK to the sensor board
- Plug the HDK programming adapter into the health sensor board at the USB type-C connector.
- Connect the HDK to a PC
- Connect your PC to the HDK board at the micro-USB connector marked HDK. After a few seconds of activity, the PC will recognize the mbed Microcontroller as a standard USB drive
- Press the button on the sensor board
- Check PC configuration as guided here
- https://developer.mbed.org/platforms/MAX32620HSP/
- (Tips: Find words "PC Configuration" on this page where you may find the starting steps)
