8 years, 7 months ago.
Unable to make the mbed-os-example-mesh-minimal work
I use the FRDM-K64 + Atmel AT86RF233 boards, and the mbed gateway
I flashed the mbed gatemay with the firmware located in mbed-os-example-client/GW_Binary: gatewayThreadDynamic.bin
For the device (K64F), I modified "mbed_app.json" for Thread configuration: /media/uploads/cle_ment/mbed_app.json
I compile with "mbed compile -m K64F -t GCC_ARM"
In first I turn on the mbed gateway, then the FRDM-K64.
The gateway seems to be connected to Internet but the IP of the K64 board is a local IP (fd00:db8::ff:fe00:0) and I can't ping this adress with a PC connected to the same network than the gateway.
Any idea why?
Below the logs of both the gateway and the K64 board:
