9 years ago.
USBSerial and Serial interrupt
I have a problem with the following code. At first I used only serial interrupt and everything worked good. I put USBSerial interrupt to my code where the code waits to received character "1". The problem is that nothing works at the moment. Neither serial interrupt nor USB serial interrupt. I do not know where is a bug.
#include "USBSerial.h"
#include "MODSERIAL.h"
#include "at25sf041.h"
//#include "rtos.h"
DigitalOut LedStatus(P0_13);
DigitalOut LedBattery(P0_14);
DigitalOut USB_connect(P0_6);
AnalogIn ain(P0_11);
USBSerial usb(0x1f00, 0x2012, 0x0001, false);
DigitalIn Vbus(P0_3);
AT25SF041 memory(P0_9, P0_8, P0_10, P0_15);
MODSERIAL uart(P0_19, P0_18);
InterruptIn GPS_fix(P0_17);
volatile bool newline_detected = false;
char tmp;
void Rx_interrupt(MODSERIAL_IRQ_INFO *q)
MODSERIAL *serial = q->serial;
if ( serial->rxGetLastChar() == '\n') {
newline_detected = true;
LedBattery = !LedBattery;
void toogle()
LedStatus = !LedStatus;
void usb_rx()
tmp = usb.getc();
int main(){
USB_connect = 0;
GPS_fix.rise(&toogle);
usb.attach(&usb_rx);
uart.baud(9600);
uart.attach(&Rx_interrupt, MODSERIAL::RxIrq);
while (1)
// if (usb.readable())
// LedStatus = !LedStatus;
// tmp = usb.getc();
if (tmp == '1' && newline_detected) {
char c;
while((c = uart.getc()) != '\n') {
usb.putc(c);
usb.printf("\r\n");
//tmp = ' ';
8 years, 6 months ago.
I have similar problem with one of my projects. It seems that that mbed-rtos causes USBSerial.getc() to block in interrupts. With normal serial ports this can be resolved by accessing the serial registers directly inside the interrupt. With UsbSerial I don't know a proper solution yet.
USBSerial.getc() seems to start jamming in the interrupt after mbed-rtos is added to the project (even when rtos.h is not included).
If you're using mbed-rtos, I would recommend using the latest release of mbed, mbed OS, which includes mbed-rtos in the library. See Serial documentation here - https://docs.mbed.com/docs/mbed-os-api-reference/en/latest/APIs/interfaces/digital/Serial/
posted by 01 Sep 2017
