9 years, 1 month ago.
LPC1549: Using Internal clock
1) Do I have to make any changes in the mbed lib for it to use the external 12MHz crystal?
2) I want to avoid an external crystal. It may not be possible since my CAN bus can run at 500k freq. Correct?
3) If i use external crystal how can I be sure that the crystal is being used? Does the chip autoswitch between internal clock and external crystal?
4) I have created simplistic board without a crystal and have pushed a simple UART program and it doesnt seem to work. With external crystal it works
thanks a bunch
The clock setting for the device is in the CMSIS startup code which is in the pre-built binary of mbed library. So, you need to use either mbed-dev libray (online compiler), or offline compiler.
I don't have an answer for this question because it is device specific. You may ask NXP LPC comminity site: https://community.nxp.com/community/lpc
I don't think the chip autosiwtch clock source. Please refer LPC15xx users manual (maybe in SYSCON).
Watarai-San
I see the following variables in system_LPC15XX.c
<<code>> <h> System Oscillator Control (SYSOSCCTRL) <o.0> BYPASS: System Oscillator Bypass Enable <i> If enabled then PLL input (sys_osc_clk) is fed <i> directly from XTALIN and XTALOUT pins.
SYSOSCCTRL_Val = 0 CHANGED TO BYPASS
<o.0..1> System PLL Clock Source Select (SYSPLLCLKSEL) <0=> IRC Oscillator <1=> Crystal Oscillator (SYSOSC)
  1. define SYSPLLCLKSEL_Val 0x00000000 CHANGED TO 0 TO USE IRC
MAINCLKSELA_Val =0 SET TO USE IRC MAINCLKSELB_Val=0 SET TO USE SELA
<<code>>
Are these the changes you are referring to these changes. We made this and its not working with these changes..
Need your help please
posted by Surendar S 04 Mar 2017
I quickly tested the IRC for the LPC1549 and this worked with simple blinky and printf serial output. /media/uploads/MACRUM/system_lpc15xx.c
posted by Toyomasa Watarai 04 Mar 2017
