9 years, 1 month ago.
BLE waitForEvent() not working - nRF52
Having an issue with the BLE waitForEvent() function.
Problem: waitForEvent() is completely ignored by my nRF52 mBED program. This happens also with sample BLE programs provided. Tested on multiple nRF52_DK boards. mBED 5.0. Would have sworn it was working correctly about a month ago.
Example program below. Output = YESYESYESYES.... without interacting with the device.
Why doesn't the waitForEvent() function, actually wait for a BLE event? E.g. smartphone connecting/writing to characteristic/etc ?
Any help would be amazing.
#include "ble/BLE.h"
DigitalOut led(LED1, 1);
uint16_t customServiceUUID  = 0xA000;
uint16_t readCharUUID       = 0xA001;
uint16_t writeCharUUID      = 0xA002;
const static char     DEVICE_NAME[]        = "ChangeMe!!"; // change this
static const uint16_t uuid16_list[]        = {0xFFFF}; //Custom UUID, FFFF is reserved for development
/* Set Up custom Characteristics */
static uint8_t readValue[10] = {0};
ReadOnlyArrayGattCharacteristic<uint8_t, sizeof(readValue)> readChar(readCharUUID, readValue);
static uint8_t writeValue[10] = {0};
WriteOnlyArrayGattCharacteristic<uint8_t, sizeof(writeValue)> writeChar(writeCharUUID, writeValue);
/* Set up custom service */
GattCharacteristic *characteristics[] = {&readChar, &writeChar};
GattService        customService(customServiceUUID, characteristics, sizeof(characteristics) / sizeof(GattCharacteristic *));
 *  Restart advertising when phone app disconnects
void disconnectionCallback(const Gap::DisconnectionCallbackParams_t *)
    BLE::Instance(BLE::DEFAULT_INSTANCE).gap().startAdvertising();
 *  Handle writes to writeCharacteristic
void writeCharCallback(const GattWriteCallbackParams *params)
    /* Check to see what characteristic was written, by handle */
    if(params->handle == writeChar.getValueHandle()) {
        /* toggle LED if only 1 byte is written */
        if(params->len == 1) {
            led = params->data[0];
            (params->data[0] == 0x00) ? printf("led on\n\r") : printf("led off\n\r"); // print led toggle
        /* Print the data if more than 1 byte is written */
        else {
            printf("Data received: length = %d, data = 0x",params->len);
            for(int x=0; x < params->len; x++) {
                printf("%x", params->data[x]);
            printf("\n\r");
        /* Update the readChar with the value of writeChar */
        BLE::Instance(BLE::DEFAULT_INSTANCE).gattServer().write(readChar.getValueHandle(), params->data, params->len);
 * Initialization callback
void bleInitComplete(BLE::InitializationCompleteCallbackContext *params)
    BLE &ble          = params->ble;
    ble_error_t error = params->error;
    if (error != BLE_ERROR_NONE) {
        return;
    ble.gap().onDisconnection(disconnectionCallback);
    ble.gattServer().onDataWritten(writeCharCallback);
    /* Setup advertising */
    ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::BREDR_NOT_SUPPORTED | GapAdvertisingData::LE_GENERAL_DISCOVERABLE); // BLE only, no classic BT
    ble.gap().setAdvertisingType(GapAdvertisingParams::ADV_CONNECTABLE_UNDIRECTED); // advertising type
    ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::COMPLETE_LOCAL_NAME, (uint8_t *)DEVICE_NAME, sizeof(DEVICE_NAME)); // add name
    ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::COMPLETE_LIST_16BIT_SERVICE_IDS, (uint8_t *)uuid16_list, sizeof(uuid16_list)); // UUID's broadcast in advertising packet
    ble.gap().setAdvertisingInterval(100); // 100ms.
    /* Add our custom service */
    ble.addService(customService);
    /* Start advertising */
    ble.gap().startAdvertising();
 *  Main loop
int main(void)
    /* initialize stuff */
    printf("\n\r********* Starting Main Loop *********\n\r");
    BLE& ble = BLE::Instance(BLE::DEFAULT_INSTANCE);
    ble.init(bleInitComplete);
    /* SpinWait for initialization to complete. This is necessary because the
     * BLE object is used in the main loop below. */
    while (ble.hasInitialized()  == false) { /* spin loop */ }
    /* Infinite loop waiting for BLE interrupt events */
    while (true) {
        ble.waitForEvent(); /* Save power */
        printf("YES");
8 years, 10 months ago.
insert a Ticker() function to wake up the process.
