9 years, 1 month ago.
MAX32630FTHR ADC
I am trying to work with the ADC. I define the analog inputs as follows:
AnalogIn ch0(AIN_0); ADC input AnalogIn ch1(AIN_1); ADC input AnalogIn ch2(AIN_2); ADC input AnalogIn ch3(AIN_3); ADC input
I get the following compiler error:
/media/uploads/PowerIC/compiler_error.png
I could not find an example, so I am basically porting mBed ADC code that works on other mBed enabled platforms. Is there something different on the MAX32630FTHR?
Maxim's microcontrollers provide low-power, efficient, and secure solutions for challenging embedded applications.
Bill, The path in your error message calls out an old development library. Please change to the official mbed-os library. Our latest examples at our MAX32630FTHR APPS wiki page all use the official library now.
This example uses the analog inputs:
Import programFTHR_OLED
Adafruit FeatherOLED example for the MAX32630FTHR board
Thank you Greg! Works like a charm now.
posted by Bill Smith 21 Feb 2017
Hello Bill,
Please see the following example, https://developer.mbed.org/users/j3/code/MAX32630FTHR_ADC_Example/file/047c43d8b360/main.cpp
Links to analogin_api.c for both mbed-os and mbed-2.0 showing the configuration of an ADC channel when using the mbed API.
https://github.com/ARMmbed/mbed-os/blob/master/targets/TARGET_Maxim/TARGET_MAX32630/analogin_api.c
https://developer.mbed.org/users/mbed_official/code/mbed-dev/file/b23ee177fd68/targets/TARGET_Maxim/TARGET_MAX32630/analogin_api.c
I hope this helps.
Thanks, Justin
Bill,
I verified the example above with mbed-os as well. You can delete the reference to 'mbed' in the project above and include 'mbed-os' if that is what you are using.
Thanks, Justin
posted by Justin Jordan 21 Feb 2017
Thank you for your help Justin, and the excellent adc example.
