9 years, 1 month ago.
Problem with this program, I can't send a caracter this an application android, "Error 507",please?
/* mbed Microcontroller Library
- Copyright (c) 2006-2015 ARM Limited
- Licensed under the Apache License, Version 2.0 (the "License");
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an "AS IS" BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
- include "mbed.h"
- include "ble/BLE.h"
- include "ble/services/HeartRateService.h"
DigitalOut led1(LED1, 1);
const static char DEVICE_NAME[] = "HRM1"; static const uint16_t uuid16_list[] = {GattService::UUID_HEART_RATE_SERVICE};
static volatile bool triggerSensorPolling = false;
void disconnectionCallback(const Gap::DisconnectionCallbackParams_t *params) { (void)params; BLE::Instance().gap().startAdvertising(); restart advertising }
void periodicCallback(void) { led1 = !led1; /* Do blinky on LED1 while we're waiting for BLE events */ /* Note that the periodicCallback() executes in interrupt context, so it is safer to do
- heavy-weight sensor polling from the main thread. */ triggerSensorPolling = true; }
void onBleInitError(BLE &ble, ble_error_t error) { (void)ble; (void)error; /* Initialization error handling should go here */ }
void bleInitComplete(BLE::InitializationCompleteCallbackContext *params) { BLE& ble = params->ble; ble_error_t error = params->error;
if (error != BLE_ERROR_NONE) { onBleInitError(ble, error); return; }
if (ble.getInstanceID() != BLE::DEFAULT_INSTANCE) { return; }
ble.gap().onDisconnection(disconnectionCallback);
/* Setup primary service. */ uint8_t hrmCounter = 60; init HRM to 60bps HeartRateService hrService(ble, hrmCounter, HeartRateService::LOCATION_FINGER);
/* Setup advertising. */ ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::BREDR_NOT_SUPPORTED | GapAdvertisingData::LE_GENERAL_DISCOVERABLE); ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::COMPLETE_LIST_16BIT_SERVICE_IDS, (uint8_t *)uuid16_list, sizeof(uuid16_list)); ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::GENERIC_HEART_RATE_SENSOR); ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::COMPLETE_LOCAL_NAME, (uint8_t *)DEVICE_NAME, sizeof(DEVICE_NAME)); ble.gap().setAdvertisingType(GapAdvertisingParams::ADV_CONNECTABLE_UNDIRECTED); ble.gap().setAdvertisingInterval(1000); /* 1000ms */ ble.gap().startAdvertising();
infinite loop while (true) { check for trigger from periodicCallback() if (triggerSensorPolling && ble.getGapState().connected) { triggerSensorPolling = false;
Do blocking calls or whatever is necessary for sensor polling. In our case, we simply update the HRM measurement. hrmCounter++;
60 <= HRM bps <= 100 if (hrmCounter == 100) { hrmCounter = 60; }
update bps hrService.updateHeartRate(hrmCounter); } else { ble.waitForEvent(); low power wait for event } } }
int main(void) { Ticker ticker; ticker.attach(periodicCallback, 1); blink LED every second
BLE::Instance().init(bleInitComplete); }
