9 years, 1 month ago.
Dead mbed LPC 1768
I recently discovered a NXP LPC 1768 in my lab, sadly connecting it to USB supply does not even get the LEDs to blink or detection by the PC whatsoever (Yes I have the drivers installed and tried different USB ports and cables).
Have read through the post here: https://developer.mbed.org/cookbook/deadmbed and as per them the next move should be to send it for repairs.
What I observed strangely is that the power is being cut right at the input regulator stage. I tested the pins of the onboard regulators (LD33) and there was no supply on either the input or the output pins. That leads me to guess that the damaged components should be way before them in the circuit probably a trivial resistor/diode(maybe).
I also tested the presence of 5V at the power line of USB on the board (thus eliminating a cable fault)
As such the board is bricked I would like to attempt some troubleshooting based on the direction of the far experienced here. Very eager to try my hands on a working Cortex board after a reasonable stint on Arduino's.
Thanking in anticipation
Thanks for getting in touch :)
Firstly have you had a look at: https://developer.mbed.org/cookbook/deadmbed
Can you let me know which stage is applicable to you?
How did board come to be damaged?
Have you tried powering it by VIN, rather than the USB?
For reference here is the schematic for the LPC1768: https://developer.mbed.org/media/uploads/chris/mbed-005.1.pdf
Page 2 shows the power supply circuit, this should further help you debug the problem, possibly the diode is broken.
Andrea, team mbed
