9 years, 1 month ago.
NUCLEO-L476RG not working
Simple hello world program works on NUCLEO-F411RE but not on NUCLEO-L476RG.
DigitalOut blink(PC_3); int main() { bool toggle=false; while(1) { if (toggle) blink.write(1); else blink.write(0); wait(0.2); toggle = !toggle; } }
LED blinks with F411RE board but remains off with L476RG board.
No success even after following instructions to upgrade firmware mentioned here: https://developer.mbed.org/teams/ST/wiki/Nucleo-Firmware
I also don't get any result even when trying to use other port pins.
Please help, I have bought 4 of these (L476RG) development boards thinking that they should work just the same as my previous F411-RE boards have worked...
Darmesh Nana
Further information. Flash drive on L476RG contains details text file with the following content "Version: 0221 Build: Nov 17 2016 13:37:06"
posted by Darmesh Nana 08 Feb 2017
Hi Darmesh,
I don't think "PC_3" should be used as DigitalOut from the PinMaps. You could check the PinMaps from here and select correct one: https://developer.mbed.org/platforms/ST-Nucleo-L476RG/
BR, Fred.
posted by Fred Li 09 Feb 2017
I have found that on L476RG it also relates to serial port that I have defined. With definition Serial lcd4D(PC_1, PC_0) the blinking pin does not work. With definition Serial lcd4D(PA_2, PA_3) the blinking pin works.
So my conclusion is that use of Serial Port on pins PC_1 & PC_0 is incorrect or not supported (Serial1)
posted by Darmesh Nana 10 Feb 2017
