8 years, 12 months ago.
Can't change system clock on lpc11u35
I'm having a little problem with changing the system clock in a LPC11u35 (I have the QuickStart board).
So, I want to run the MCU the fastest possible (48MHz according to the datasheet). To do so, I've configured the PLL as the system clock source.
The code in question:
void setClk()
// Power up PLL
LPC_SYSCON->PDRUNCFG &= ~(0x00000080);
// Set oscillator as PLL input
LPC_SYSCON->SYSPLLCLKSEL |= 0x00000001;
// Reset PLL
LPC_SYSCON->SYSPLLCLKUEN &= ~(0x00000001);
LPC_SYSCON->SYSPLLCLKUEN |= 0x00000001;
// Set PLL output to 48MHz
LPC_SYSCON->SYSPLLCTRL &= ~(0x0000007F);
LPC_SYSCON->SYSPLLCTRL |= 0x00000003; // (M = 4)
LPC_SYSCON->SYSPLLCTRL |= 0x00000020; // (P = 2)
// Wait until PLL has locked
while((LPC_SYSCON->SYSPLLSTAT & 0x00000001) == 0);
// Set main clock to PLL
LPC_SYSCON->MAINCLKSEL &= ~(0x00000003);
LPC_SYSCON->MAINCLKSEL |= 0x00000003;
LPC_SYSCON->MAINCLKUEN &= ~(0x00000001);
LPC_SYSCON->MAINCLKUEN |= 0x00000001;
SystemCoreClockUpdate();
I have even called the method SystemCoreClockUpdate() to update the SystemCoreClock variable (I don't know what is it for, but I suppose peripherals libraries use it). I have read in execution its value, and it is 48MHz.
So... it appears to be working, why do I ask this question?
Well, when I measure a 1sec pulse using one of the 32bits counters, I always get the same reading of about 1 mil (as if the MCU was running at 1MHz). I have to point out that I'm also using USBSerial library, and an InterruptIn object. Anybody has a clue?
Thanks!
This is the main code:
#include "USBSerial.h"
DigitalOut LedStatus(P0_13);
InterruptIn Pulse(P0_17);
USBSerial serial;
unsigned int count;
void toggle()
// Read count
count = LPC_CT32B1->TC;
// Reset CT32B1
LPC_CT32B1->TCR |= 0x00000002;
LPC_CT32B1->TCR &= ~(0x00000002);
// print count via USB
serial.printf("*****%d*******", count);
setClk();
// Enable 1 sec pulse interrupt
Pulse.rise(&toggle);
// Enable timer CT32B1
LPC_SYSCON->SYSAHBCLKCTRL |= 0x00000200;
// Set precounter to 0
LPC_CT32B1->PR |= 0x00000000;
// Start CT32B1
LPC_CT32B1->TCR |= 0x00000001;
while(1);
Try using CT32B0 instead. B1 is already used for things like wait and Ticker. Which sets it to run at 1MHz using its prescaler. (Or one of the 16-bit timers).
It runs by default at 48MHz, otherwise USBSerial also wouldn't work. So the reason you are always seeing the same, is that your code does not actually change anything. See: https://github.com/ARMmbed/mbed-os/blob/master/targets/TARGET_NXP/TARGET_LPC11UXX/device/system_LPC11Uxx.c#L148
Now I have seen better documented clock setup files, however important is that SYSPLLCTRL is set to 0x23, which is identical to what you set it to.
