9 years, 1 month ago.
Adding a new CPU to mbed
I am trying to add a new CPU variant to mbed OS 5.0 called NEWCPU. For SDK porting it is mentioned that we should add the Target CPU to the file /mbed-os/targets/targets.json.
I added the following to the targets.json file.
"NEWMCU": { "inherits": ["Target"], "core": "Cortex-M4", "default_toolchain": "GCC_ARM", "supported_toolchains": ["GCC_ARM"], "extra_labels": ["Companyname", "Newcpu"], "macros": [], "public": true "device_has": ["PORTIN", "PORTINOUT", "PORTOUT"] },
But when I compile the code by calling mbed compile -m NEWCPU, it gives me an error saying Unsupported CPU type and lists the available list of MCU's but my CPU name does not show in that list
I see mbed compile calls on the make.py, but at which point will make.py use the NEWCPU from the targets.json file.
Thank you for reading this and providing some solution.
Hey Royston,
You seem to have followed the guide exactly, except for one thing: you need a `release_versions` key which would contain `["5"]`. Let me know if that's not in the guide.
Could you give that a try?
-Jimmy
Thank your reply, No the release_versions key is not mentioned in the porting guide. I tried adding it the json file, but it still doesn't work. Apparently make.py is using the json file inside .temp/tools If I add the newmcu to that json file the make.py is able to find the mcu and compiles. If I add the same CPU definition to json file in mbed-os/targets it doesnt work.
"NEWMCU": { "inherits": ["Target"], "core": "Cortex-M4", "default_toolchain": "GCC_ARM", "supported_toolchains": ["GCC_ARM"], "extra_labels": ["CompanyName", "McuName"], "macros": [], "public": true, "device_has": ["PORTIN", "PORTINOUT", "PORTOUT"], "device_name": "McuName", "release_versions": ["5"] },
posted by 03 Feb 2017Ah. I take it that you are using mbed-dev then.
If you are looking to add new targets, I recommend that you use the mbed-os repo here: https://github.com/ARMmbed/mbed-os as mbed-cli will not add a hidden folder containing the tools and the tools will use the target.json from that repo by default.
posted by 03 Feb 2017Thank you Jimmy. Yes, I am using mbed-cli. I don't want to add the target inside the hidden folder, I want to add the new target using the method recommended by mbed i.e. by adding the definition to mbed-os/targets/ targets.json. Is there a reason mbed compile (make.py) is not picking up the new target from there? Is there a potential fix to this?
Thank you
posted by 03 Feb 2017So, supposing that you are using the mbed-os that I recommended, as mbed-os.lib, mbed-cli should be using `make.py` from `mbed-os/tools/make.py` (you can check with `-v` appended to your mbed-cli command). That version of `make.py` should be using `mbed-os/targets/targets.json` as it's source of targets.
If this is not the case, then we really should start looking at the files in your workspace. -Jimmy
