9 years, 2 months ago.
.lib in export folder
In the export folder I can find some *.lib files which are not in the IDE. For what reason they are exist and when will they generated? What is the contents of that .lib files?
Hi Hans,
The *.lib files are used to track which libraries your project is using. In the IDE these show up as library folders (should be a "gear" icon I believe). Generally you should leave these alone and let the IDE or mbed CLI deal with them. For more information you can always check the mbed CLI documentation.
Thanks, Brian
