9 years, 1 month ago.
How / Is there a way to cancel a Timeout?
I initiate a timeout for a duration. On completion, it will call a function. Is there a way to cancel the timeout, in case it is not used anymore for this run. For example, I want to read some value, but not want to wait more than a certain amount of time. I created a timeout , but in case the request complete before the timeout, I don't want to be called back. What would be the proper way to do it? Thanks
Typically the timeout is cancelled when you attach the NULL pointer to the Timeout object instead of the original function.
