9 years, 2 months ago.
How to set Static IP address with Nucleo F767ZI?
Hi,All.
I have a Nucleo F767ZI board.
The following sample program worked normally(with DHCP address).
"New -> Nucleo-F767ZI -> A small example of TCP server over ethernet for mbed-OS"
However, setting a static IP address as described below will result in an error.
main.cpp
#if !FEATURE_LWIP
#error [NOT_SUPPORTED] LWIP not supported for this target
#endif
#include "TCPServer.h"
#include "TCPSocket.h"
#define HTTP_STATUS_LINE "HTTP/1.0 200 OK"
#define HTTP_HEADER_FIELDS "Content-Type: text/html; charset=utf-8"
#define HTTP_MESSAGE_BODY "" \
"<html>" "\r\n" \
" <body style=\"display:flex;text-align:center\">" "\r\n" \
" <div style=\"margin:auto\">" "\r\n" \
" <h1>Hello World</h1>" "\r\n" \
" <p>It works !</p>" "\r\n" \
" </div>" "\r\n" \
" </body>" "\r\n" \
"</html>"
#define HTTP_RESPONSE HTTP_STATUS_LINE "\r\n" \
HTTP_HEADER_FIELDS "\r\n" \
"\r\n" \
HTTP_MESSAGE_BODY "\r\n"
printf("Basic HTTP server example\n");
EthernetInterface eth;
//eth.init("192.168.3.24","255.255.252.0","192.168.3.1"); // <---------- Compile Error
//eth.init(); // <----------------------------------------------------- Compile Error
eth.connect();
printf("The target IP address is '%s'\n", eth.get_ip_address());
TCPServer srv;
TCPSocket clt_sock;
SocketAddress clt_addr;
/* Open the server on ethernet stack */
srv.open(ð);
/* Bind the HTTP port (TCP 80) to the server */
srv.bind(eth.get_ip_address(), 80);
/* Can handle 5 simultaneous connections */
srv.listen(5);
while (true) {
srv.accept(&clt_sock, &clt_addr);
printf("accept %s:%d\n", clt_addr.get_ip_address(), clt_addr.get_port());
clt_sock.send(HTTP_RESPONSE, strlen(HTTP_RESPONSE));
Please tell me how to solve.
9 years ago.
Your problem is you the wrong member function. You must use the following function.
eth.set_network("192.168.3.24","255.255.252.0","192.168.3.1");
or with macros... it's somthing like this
eth.set_network(IP_Adress,GATEWAY,MASK);
but the problem is, on my NUCLEO F767ZI i can only connect to my tcp-server when i'm using DHCP. When i'm try to use static IP my NUCLEO F767ZI didn't answer the "how has" (ARP) question (didn't sends his MAC-Adress) from the clint....
