9 years, 1 month ago.
How to use LSE for RTC on the Nucleo-L476RG
Hello, I am configuring RTC with LSE, the crystal is on-board (X2) but I can't see it oscillate with my scope. However the RTC is working well and I can get the time without problem. I don't understand what I am doing wrong. Any help would be appreciated.
Here is my code :
__HAL_RCC_PWR_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
// Reset Backup domain
__HAL_RCC_BACKUPRESET_FORCE();
__HAL_RCC_BACKUPRESET_RELEASE();
RCC_OscInitTypeDef handle_RCC_Osc;
RCC_PeriphCLKInitTypeDef handle_RCC_Clk;
handle_RCC_Osc.OscillatorType = RCC_OSCILLATORTYPE_LSE;
handle_RCC_Osc.PLL.PLLState = RCC_PLL_NONE;
handle_RCC_Osc.LSEState = RCC_LSE_ON;
handle_RCC_Osc.LSIState = RCC_LSI_OFF;
if(HAL_RCC_OscConfig(&handle_RCC_Osc) != HAL_OK)
pc.printf("Error HAL_RCC_OscConfig \r\n");
handle_RCC_Clk.PeriphClockSelection = RCC_PERIPHCLK_RTC;
handle_RCC_Clk.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
if(HAL_RCCEx_PeriphCLKConfig(&handle_RCC_Clk) != HAL_OK)
pc.printf("Error HAL_RCCEx_PeriphCLKConfig \r\n");
// Enable RTC Clock
__HAL_RCC_RTC_ENABLE();
handleRTC.Instance = RTC;
handleRTC.Init.HourFormat = RTC_HOURFORMAT_24;
handleRTC.Init.AsynchPrediv = 0x7F;
handleRTC.Init.SynchPrediv = 0x00FF;
handleRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
handleRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
handleRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if(HAL_RTC_Init(&handleRTC) != HAL_OK)
pc.printf("Error Hal_RTC_init \r\n");
RTC_DateTypeDef date;
date.WeekDay = RTC_WEEKDAY_WEDNESDAY;
date.Month = RTC_MONTH_AUGUST;
date.Date = 31;
date.Year = 16;
RTC_TimeTypeDef time;
time.Hours = 15;
time.Minutes = 42;
time.Seconds = 0;
time.TimeFormat = RTC_HOURFORMAT12_PM;
if (HAL_RTC_SetDate(&handleRTC, &date, RTC_FORMAT_BIN) != HAL_OK)
pc.printf("Error Set Date \r\n");
if (HAL_RTC_SetTime(&handleRTC, &time, RTC_FORMAT_BIN) != HAL_OK)
pc.printf("Error Set Time \r\n");
Thanks.
Hi Jonathan, my understanding is that the LSE is turned on by default using mbed. I use the RTC on the 476 Nucleo, it works. You don't need to do anything with the HAL APIs. I use the mbed API set_time() to set the time and time()/localtime() to read the time. For Wakeups I use the "WakeUpRTC" library from Erik Olieman available here at mbed, his library calls “rtc_init()”
You will not see the crystal clock with a scope because the load of the scope is too much for the crystal.
Regards Helmut
